    SUp to Cinema 4D?
    8 Posts 3 Posters 2.3k Views 3 Watching
    • Joe WoodJ Offline
      Joe Wood
      Can I convert a SUp file so it can be viewed and measured by somwone using Cinema 4D?
      Joe Wood
      woodsshop.com/
        If 4D has measuring tools then yes.
        Export to OBJ and make sure model units and Swap Axis is checked.
        • Joe WoodJ Offline
          Joe Wood
          Right on Rich I'll give it a try!
          Joe Wood
          woodsshop.com/
          • Joe WoodJ Offline
            Joe Wood
            Say Rich, should I select any of the model units like ' or cm? This is going to someone over in the UK if that matters.
            Joe Wood
            woodsshop.com/
              OBJ by default uses its own units. Setting the export to match the model units in SketchUp means the app importing can apply the correct scale.
              So if you model in CM then exports in CM.
              I'm more interested to know if Cinema 4D dimensions meshes. There's a paid plugin...
              http://lesterbanks.com/2014/03/measure-creates-flexible-dimensioning-cinema-4d/
              ...so it suggests that Cinema 4D doesn't dimension as standard.
              • Joe WoodJ Offline
                Joe Wood
                So check out what Gus did https://www.shijima.co.uk/ scroll down a bit to my moon gate pics then under is a model he built and rendered from the file I sent him! Look at the texture on the round moon gate faces, how it follows the curve around πŸ™‚
                Joe Wood
                woodsshop.com/
                • pbacotP Offline
                  That's a beautiful render video and a great model, beautiful design. You can apply texture to orient like that in SketchUp. With Fredo's Thrupaint and other ways. First find a circular board!
                  Long grain wood material from Sketchucation!
                  • Joe WoodJ Offline
                    Joe Wood
                    Hey Rich, Gus is totally stoked with the new measuring tool he has πŸ™‚ Thanks for suggesting that!
                    Joe Wood
                    woodsshop.com/
