    Shadows in render not changing
    renderpluginsextensions
    2 Posts 2 Posters 1.6k Views 2 Watching
      mixzzz007
      Hey,
      So the problem is that when I'm trying to change the direction of sketchup shadows it doesn't change when rendering, still renders the same no matter what I direct to. What could be the symptom?
      • renderizaR Offline
        renderiza
        In the V-Ray Asset Editor...
        Do you have SunLight Enabled?
        Or Do you have a V-Ray Omni Light Enabled instead?
        You might need to disable the omni light and re-enable SunLight.
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
