    Section Fills in 2018
    2 Posts 2 Posters 996 Views 2 Watching
    • EdsonE
      Edson
      Is anyone having trouble with section fills in 2018? Because I am not getting along very well with this new feature.
      It creates the section cut as a group but it not easy to find it. And when moves the section it does not seem to refresh it.
      SectionCutFace by TIG puts the section cut in a layer and that makes it so much easier to use.
      Any ideas?
      http://www.mahfuz.arq.br
        The section fill doesn't create a group on its own. If you use Create group from slice you do get a group and of course it's only the outline. There's no face. It can be difficult to see and select that group if there's a fill and especially if the fill color is black. You can change the fill color, of course, or you could select the group in Outliner.
        I'm not seeing any issues with the fill updating when moving the section cut. The group from slice doesn't update but then it never did.
