    Missing Sketchucation Extensions
    extensions
    2 Posts 2 Posters 1.9k Views 2 Watching
    • P Offline
      Peter19
      Hello,
      I recently upgraded from 2017 SketchUp Pro to 2018 SketchUp Pro and I have been trying to reinstall all the plugins that disappeared when I did that upgrade. I've managed to reinstall most of the extensions found through the Extension Warehouse, but I'm confused about how to get back the Sketchucation extensions I had previously installed in 2017 Pro. Does anyone have any ideas?
      Thanks,
      Peter
        You can download the latest individual item's RBZs from:
        https://sketchucation.com/pluginstore
        then use the native Installer...
        You can also [re]install the SketchUcation Toolset:
        https://sketchucation.com/resources/plugin-store-download
        Then use its "ExtensionStore³" dialog to "Auto-install" selected items from the SketchUcation PluginStore.
        If you had this tool already installed in the previous version, then you might have some 'Bundles' set up or at least 'Updates' showing as being available - access this via the 'cog' icon in the dialog's top bar...
        These allow en mass Auto-installation of the latest versions of relevant RBZs...
