    Hdri envoirment matching to model
    renderpluginsextensions
    4 Posts 3 Posters 1.5k Views 3 Watching
      bagtoshop
      im trying to match an hdri image to my model. but im having problems to make the sky all over the house. its just half of the photo and i want to make it more realistic so the hdri will cover most of the photo.
      how the settings need to be ?
      see attach of the last render photo.
        bagtoshop
        im attaching you example of how i want the hdri to be in my rendering.
        • filibisF Offline
          filibis
          Make sure that shape is set to 'Sphere' and not 'Hemisphere'. (Check this)
          Also note that your HDR image might be just hemisphere or panoramic, so try different one in that case.
            rv1974
            Mind-blowing questions!
            Just put camera lower, make FOV way LARGER, lift camera's target up.
            I atrongly believe you could find the solution by yourself
