    Extension/Plugin makes Sketchup unstable
    extensions
    4 Posts 2 Posters 2.1k Views 2 Watching
      Moky
      I installed a few new extensions/plugins to improve my workflow. But now sketch up crashes all the time. I close one open sketch window and sketch up crashes. I am also not
      I installed these extensions:
      Curvizard
      Curviloft
      FredoScale
      RoundCorner
      Bezier Curves
      Shape Bender
      Joint push pull
      sandbox
      soap bubble
      I am at a point where I consider to reinstall sketchup, since I can't close a window.
      Does anyone else have these problems?
      Inga
      • TIGT Online
        The native toolset 'Sandbox' auto-installs [in Pro].
        So there is no need for you to 'install' it ?
        The questionable one is perhaps 'Soap bubble' - it needs to be the latest compatible version ??
        Where did you get it from ???
        'Shape Bender' should be OK - but get the latest version from the EWH just in case...
        The rest that you listed seem to be Fredo's tools, and these will all need his Lib installing...
        You didn't mention you had that ?
        https://sketchucation.com/pluginstore?pln=LibFredo6
          Moky
          I work with Sketchup 2016 pro.
          About Soap bubble, I downloaded it from this webpage.
          I tried to get the newest version of every plugin.
          And yes I also have the latest version of Lib.
          Unfortunately just turning the plugins off doesn't make a difference. Is there any other way, or do I need to reinstall Sketch up?
            Moky
            Thanks,
            I am working with SU 2016 pro. I had no idea that Sandbox would autoinstall. Maybe not on the version I have though.
            I downloaded all plugins from this webpage and made sure that I have the latest versions, Lib included.
            Is there any way how to remove the plugins that I can test it? Just turning them off doesn't make a difference.
