    Alpha image is ignoring objects after the glass
    renderpluginsextensions
    4 Posts 3 Posters 3.4k Views 3 Watching
    • flordelisF Offline
      flordelis
      Hello everyone!
      I have a problem that I tried many things and can't solve.
      I'm making an image with a window and a balcony on the outside. The alpha image is showing only the window and ignoring the balcony. And with that I can't put a background image in photoshop, because it would make the balcony disappear.
      Anyone with the same problem?
      I'm using sketchup 2017 pro and vray 3.4, never had this problem with earlier version of vray.
      https://sketchupbrasil.com/wp-content/uploads/2018/01/sacada-1.png
      https://sketchupbrasil.com/wp-content/uploads/2018/01/sacada-2.jpg
      • filibisF Offline
        filibis
        Hi florderis,
        Have a look at balcony's material parameters. There sould be 'Alpha Contribution' under 'Material Options', make sure it's not 0. Check this official manual for material parameters.
          flordelis
          That's not working. I've tried -1 in both of them, 1 in both of them and -1 in one and 1 in the other.
          The glass only appears in the alpha channel when it's in -1, and keeps ignoring the balcony. =/
            anamichelena
            Hi Flordelis,
            I was facing the same problem: trying to mask out the background through glass with complicated shapes (trees...) in the foreground.
            In my search I came up with this solution, which is not perfect but did the trick for me:
            • glass material: in the refraction menu, set 'affect channels' to 'all channels', set refraction color slider to the right (completely white)
            • add 'background' to your render elements, this can be then be used in postproduction to mask out your background, also through glass
            As you can see, it is not the perfect solution since it only seems to work when the refraction color is set to white, but maybe it can be of any help!
            Good luck!
            Ana
            hardware:
            MSI Apache Pro
            Intel Core i7-6700HQ
            16GB ram
            GeForce GTX 1060
