    Offset the position of multiple objects randomly
    6 Posts 4 Posters 1.7k Views 4 Watching
    • H Offline
      herrschnitzel
      i am searching for a Plugin that can offset the position of any object or component. Like randomly offset the position of an object between 0 to 5 cm in any or a given direction. Its not like Skatter but similar. I was searching for a Plugin which can randomly rotate multiple objects, I found "Random rotate". Is there anything like "random rotate" but for moving objects?
      Thanks in advance! πŸ˜„
      I am not searching for a rotation plugin!
      • HornOxxH Offline
        HornOxx
        @herrschnitzel said:
        ...I was searching for a Plugin which can randomly rotate multiple objects, I found "Random rotate". Is there anything like "random rotate"?...
        hmm - not sure if you mean this tool by Cris Fullmer already? - if not "Scale and Rotate Multiple" is worth a try...
        http://sketchucation.com/forums/viewtopic.php?p=139946#p139946
        never trust a skinny cook
        • H Offline
          herrschnitzel
          I have this plugin already and I'm not searching for a rotation plugin. Just look at the attached picture, something like that.
          • oceanembersO Offline
            oceanembers
            Sketchup.active_model.selection.each{|i|;
            r1 = rand(100)/50.0;
            r2 = rand(100)/50.0;
            r3 = rand(100)/50.0;
            tr = i.transformation;
            p = Geom;;Point3d.new(r1,r2,r3);
            tr2 = Geom;;Transformation.new(p);
            tr3 = tr * tr2;
            i.transformation = tr3}
            Select what you want to randomise, then run this from the ruby console. Quick and dirty but it'll do the trick...
            On another note, does anybody know why rand(2.0) isn't giving me floats?
              Maybe this ? πŸ˜„
              And you have always also the fabulous Randomly Components replacement by Sdmitch! β˜€
              • H Offline
                herrschnitzel
                Nice it works really good. Thank you.
                @pilou said:
                Maybe this ? πŸ˜„
                Wow s4u transformer is even more than I was looking for. Looks great! Thank you!! 15$ are well spend on that plugin.
