    Cannot change color in style SU2018
    6 Posts 3 Posters 1.2k Views 3 Watching
      CalypsoArt
      I don't know if I'm doing something wrong, or if this is a bug. When I try to change the color of Section Fill and Section Lines nothing happens. The preview remains black even as the color changes in the slider.
        Hmmm... I don't see any issue. First question: Did you install SU2018 correctly using Run as administrator from the right click Context menu?
        • aarondietzenA Offline
          aarondietzen
          the slider to the right of the color wheel is all the way at the bottom... That means ANY color you choose will show up as black. Slide that little guy up and you should get the color you are choosing from the wheel.
          "Imagination is more important than knowledge..."
          - Albert Einstein
            Good catch, Aaron!
              CalypsoArt
              Yep. Don't know how I missed that. I was certain I had slide it up.
                Is your screen upside down? πŸ˜„ πŸ˜„
                I prefer to use the RGB sliders so I forgot to look at the slider in your image.
