    Regrouping
    11 Posts 3 Posters 1.4k Views 3 Watching
    • K Offline
      koliboti
      Hi, I am looking for a plugin (or script) that explode selected groups and regroup each one by one.
        Exploded view ?
        • K Offline
          koliboti
          I am searching a plugin that do this automatically with selected groups. πŸ˜„
            Your screen shot doesn't provide anything useful about what you want to do. If you already have groups in your model, why would you want to explode them and remake each one?
              I believe that I understand the ask! πŸ˜‰
              Does exist a plugin who group individual volume resulting of Boolean separation! πŸ€“
              (a sort of volumes intersection)
              Maybe you can try Solid Solver by Tig!
              Or maybe better (4th 5th icons(?) )
              • K Offline
                koliboti
                Dear Dave R, Your question is justifiable... I need to regroup all of my groups, because when I make modifications on groups using FredoScale plugin, the CutList maker plugin do not recognize the changes that I make with FredoScale, but when I explode and remake a group, the cutlist cums with the right results.
                  I would have never been able to figure that out from your screen shot.
                  What is it you are doing to the groups that result in them not showing correctly in CutList? Fredoscale should correct the definition so the groups should report correctly in CutList.
                  Can you share a sample SKP file?
                  • K Offline
                    koliboti
                    Here is the SKP file.
                    ExempleSKP.skp
                      How are you generating the cut list? I don't have any problem getting the right lengths reported on your middle grouping of posts.
                      If I were drawing models like your screen shot shows, I'd be using components instead of groups.
                        Looks to me as if you need a different tool to make your cut lists.
                        • K Offline
                          koliboti
                          Here is... πŸ˜„
