    How to make a surface comply to another surface
    7 Posts 4 Posters 884 Views 4 Watching
      Hi all, I have a bullet shape (sharp at one end and has a circular plane at the other) I also have a geodesic shape. I want to array the "bullets" on the geodesic shape the make say a "flower" I wish to make the bullet's circular bottom comply or become co-planar with each geodesic plane, ensuring the center axis of the "bullet's" center axis is perpendicular to the plane of each geodesic segment. probably one at a time. how can I, or what plugin could I use to achieve this.
      Any ideas guys?
      • cottyC Offline
        cotty
        Maybe this plugin can be helpful here too: http://sketchucation.com/forums/viewtopic.php?p=138042#p138042
        my SketchUp gallery
        • BoxB Offline
          You need to correctly set the axis of the bullet component so that is has the insertion point that you want.
          https://i.imgur.com/KxcFjBi.gif
          Then you can place them manually or use a plugin like https://sketchucation.com/pluginstore?pln=clf_components_onto_faces to place them automatically.
          You need to make them Glue to any.
            COF.jpgHad trouble with the plugin. Can anyone assist?
            • cottyC Offline
              cotty
              Does a restart of SketchUp help?
              my SketchUp gallery
                Hi Cotty, I uninstalled and installed again a few times eventually got it to work (great tool BTW!) Then shape bender dissapered so I had to reload it. Now I have Shape bender and Component on face but no tool icons just in the extensions scroll down.
                • srxS Offline
                  srx
                  More advanced plugin for things like this https://extensions.sketchup.com/en/content/s4u-components
                  www.saurus.rs
