    HIDDEN LAYERS in copied scenes
    4 Posts 3 Posters 895 Views 3 Watching
    • P Offline
      pipingguy
      If a scene is created that contains hidden layers, and then a new scene is created as a copy, the hidden layers need to be re-activated. Is there a way to avoid this? The hidden layers were generated by a plugin.
      • oceanembersO Offline
        oceanembers
        Run this in the ruby console to set all layers to default behavior
        Sketchup.active_model.layers.each{|layer| layer.page_behavior=0}
        edit:
        if you only want to change the behavior of one layer, run this and substitute NAME for your layer name
        Sketchup.active_model.layers.each {|layer| if layer.name=="NAME";layer.page_behavior=0;end}
        • P Offline
          pipingguy
          Thanks! And it seems to be permanent....vs. lasting only for one session.
            slbaumgartner
            Yes - provided you save the model. Page behavior is a property of each Layer and is saved within the model.
