    Please someone help
    6 Posts 3 Posters 1.1k Views 3 Watching
    • A
      AdrianS5
      so im having an issue where the toposhaper plugin is downloaded on to my SketchUp 2016 and 2017 but when i reset and restarted the my computer and SketchUp it doesn't up on my toolbar i can't find it but i says its downloaded on to SketchUp.
        Right Click on the toolbar and see if it is listed
        • A
          AdrianS5
          it's not listed.
          • BoxB
            Did you also install Libfredo which is required to run it?
              if it is not there it is not installed.
              use our sketchucation tools to install it.
              Plugin Store Download | SketchUcation
              Extending SketchUp has never been easier with a suite of tools that make installing and disabling plugins and extensions a one click operation.
              (sketchucation.com)
              As Box says it has a dependency library it needs to run
              • A
                AdrianS5
                (sketchucation.com)
                YES!!! That helped me out thanks!
