    Ungroup grouped piece
    3 Posts 3 Posters 1.2k Views 3 Watching
    • D
      dohyungkim
      hi~I have a question about ungrouping.
      I got entire piece grouped but I need isolate some parts in a group.
      what If the parts i want to move have tons of planes so I can't hand pick each of them,
      what should I do to take it out from the group...?
      can I get some tips for doing this easy???
      I know triple click sellect entire piece / double click select planes and lines surround it
      • cottyC
        cotty
        We need an image or the model to give you any advice...
        my SketchUp gallery
          Cotty is correct. We need to see your SKP file to give you better information. In general, the best thing would have been to plan ahead and make groups as you go instead of trying to separate out the parts now.
          One option that could work, though it's a bit clunky is to copy the group with Edit>Copy. Then edit the group and erase the bits you don't wan. After you've cut it down to a single part, use Edit>Paste in place and repeat the process for another part. Continue with Paste in place and edit until you have each part in its own group.
