    Plugins
    2 Posts 2 Posters 626 Views 2 Watching
    • P
      PETERHC
      brand new to plugins just downloaded joint push pull. How do i get it to work in sketchup?
      • TIGT
        You have downloaded an RBZ file - a type of ZIP file - containing the files and folders needed by the plugin [aka an 'extension'].
        It needs to be 'installed'.
        SketchUp menu: Window > Extension Manager > Install Extension... [red button]
        Find the RBZ and install it.
        Most installed extensions are then immediately available in their [sub]menu items or toolbars - read the usage details for each one.
        BUT, in the case of most of Fredo's tools [and many of thomthom's and a few other authors] you must also install a set of helper files - in this case:
        https://sketchucation.com/pluginstore?pln=LibFredo6
        After installing the Lib, you are probably best advised to restart SketchUp to ensure everything is synced.
        You only need to install the Lib once.
        Unless of course a new version is available, and a particular extensions says it's installation is necessary.
