    How to remove a chamfer on a box?
    34 Posts 9 Posters 5.4k Views 9 Watching
    • chippwaltersC Offline
      chippwalters
      Here's a box, which is off axis and tapered. Not a few right angles. I'm wondering how best to remove the chamfer from all sides. Here's my best thinking on how to do this. I'd like to know if others have a better way?
      FILE:
      https://altuit.cloud/web/3Dnew/chamfer.skp
      Currently working with Cross-Reality technologies
      • ecatiE Offline
        ecati
        You want it to look like in the pictures. You can use Round Corner plugin.
        https://sketchucation.com/forums/viewtopic.php?t=20485
        • BoxB Offline
          Draw the two edges in using the magenta inference then pushpull.
            rv1974
            How exactly Round corner would solve this task?
            I thought of JPP (Follow pushpull)- but unfortunately it has no snap at the moment the pushed chamfer desappears. And there's 'delete coplanar edges' (of fredo6?) for one-click cleaning.
              chippwalters
              I don't think you understood the question. It was how to REMOVE chamfers, not how to ADD them. πŸ˜„
                chippwalters
                That was the first think I tried. While that works, it has lots of mouseclicks then cleanup. I think my way may be faster.
                  Best will be a plugin who special join 2 any faces by the common edges starting the chamfer (or fillet) and kill them! πŸ˜‰
                  Don't know if yet existing?
                  But that is a funny challenge with the native tools! β˜€
                    chippwalters
                    Or even a merge vertices which merged them to the second point selected (instead of the average of the two). Newtek has one called "weld" which will move all the points to the last selected. Very handy!
                    • sdmitchS Offline
                      sdmitch
                      This was my first thought as well.
                      http://sdmitch.blogspot.com/
                        rv1974
                        my try, x1 speed. suitable for simple cases. Unfortunately TT's flatten works only in Z direction.
                        Flatten, marge coplanar, TIG's fillet, make face were used
                          chippwalters
                          I like that! One could also use Vertex Tools to flatten as well. I'll have to look into TIG's fillet tool. Thanks for sharing!!!
                            rv1974
                            One couldn't. Vertex tools aren't 100% precise.
                              chippwalters
                              They've worked for me. I typically scale to ~0 two or three times in a row and haven't had any problems creating planar faces. Artisan also has a make planar feature. Both also work on non orthogonal geometry as well.
                                rv1974
                                Hmm.. Does 'make faces' work after x3 VT scale to 0 on NON-XY planes? I'll check it tomorrow.
                                  rv1974
                                  Doh! moment: I discovered Artisan's 'make planar-best'. Vertex tools are way less accurate.
                                  • K Offline
                                    kenancakir
                                    I draw a rectangle from outside of the group, make it fit with push pull tool easily, there was one egde to move with move tool and done.. πŸ˜„
                                      For this special box case with any 4 chamfers (fillets) with only native tools (a big effort from my part! πŸ’š
                                      • 4 guides lines on any of the original box = 4 clicks
                                      • Draw Oriented Rectangle (second icon of Rectangle Tools) with 3 of intersctions above = 3 Clicks
                                        Push Pull this new rectangle = 1 click
                                      Total = 7 Clicks for an original new oriented box without chamfers(fillets)! πŸ˜„
                                      Just now erase the original chamfered box! πŸ˜„
                                      • K Offline
                                        kenancakir
                                        Our ways are the same pilou.. "Thinking outside of the box" got its exact meaning.. πŸ˜„
                                          Sure, maybe there is more tricky for draw easily this rectangle with less clicks! πŸ€“
                                          What is your method ?
                                            chippwalters
                                            [attachment=0:1oo1awgy]<!-- ia0 -->GIF_erase_chamfer.gif<!-- ia0 -->[/attachment:1oo1awgy]
                                            OK. But now try it with the file I provided. A simple pushpull extrude won't get it because the sides are NOT parallel.
                                            Here's the link again...
                                            FILE:
                                            • 1 / 2
