    Match color + Vray 3.4
    renderpluginsextensions
    3 Posts 2 Posters 2.8k Views 2 Watching
    • JonFarJ Offline
      JonFar
      Hi guys.
      I'm using VRay 3.4 now, and I want to use my own textures and change them in sketchup, with "match color" tools in the edit tab
      But then when I render the scene those textures reset to their default colors...
      Am I doing something wrong?
      Is there another way to change the color/saturation of a texture with v3.4?
      Thanks for your time
      • filibisF Offline
        filibis
        Might not be exactly what you're looking for but try this as suggested here:
        If you like to change the appearance of a texture, please use the V-Ray procedural texture - Color Correction - where you would slot the a Bitmap for the 'Texture' parameter and then adjust Hue and Saturation values.
        • JonFarJ Offline
          JonFar
          thanks
          I tried that and it works
          But the older method was way easier, dont know why they changed it.
