    20' Property.
    12 Posts 3 Posters 4.5k Views 3 Watching
      Only a few feet difference and the interior is harder to package. Using a sliding partition so the greater part of the level can change between a kitchen diner and a living room depending on what you need.
      Garden
      Living room
      Bedroom
      Kitchen
      • Bryan KB Offline
        Looks really good! Kinda dim, but that may be my monitor.
          Thanks dood. Some of the dimness is my being inept at the post pro tools in Twilight, they will be adjusted. The last image is better imho.
            Dining room layout.
            Divider moved to dining room layout.
            • PixeroP Offline
              Pixero
              To fix the dimness I think you have to think like a photographer.
              You don't use the same ISO settings for exterior daylight images (ISO 100) as in interior or nigh time shots.
              Try changing ISO to 400 or 800 that is quite common when photographing indoor.
                Thanks, it's been at least 20 years since I took photo's and my trusty OM-1N is sitting in its box unused.
                Dining room setup.
                  Nothing new but, I cannot find a way to change that setting in Twilight render. Clues anyone?
                  • Bryan KB Offline
                    I don't use Twilight, but I hope this helps.
                    https://www.twilightrender.com/index.php/tutorials/67-tutorials-v2/163-post-processing-tutorial-v2
                      Thanks Bryan, I missed that.
                        I must have altered the temp of those, trying to adjust.
                        Better colour balance.
                        • Bryan KB Offline
                          Both of the new ones look great!
                            Thanks Bryan. Learning Maxwell now.
