Sphere making problem
[size=100:1hcn5h27]****[/size]
Hello,
I am trying to make a sphere with circle having 96 sides. While follow me command it does not make a sphere.
However, when you make 24 faces it does make a sphere.
What is the best solution to make it ?
Best regards,
Makarand Acharya
India -
There isn't any problem regarding side count (I just tested).
Check this: How to Make a Sphere in SketchUp
or this: How to draw a sphere -
Is this a question about Dynamic Components? or a general question about how to make a sphere and why it is failing?
If it is a general question then it is down to you attempting to make the sphere too small.
Read the thread called The Dave Method in the Tutorials section.
Register LoginAdvertisement
