    Vray 3.4 render problem
    renderpluginsextensions
    2 Posts 2 Posters 3.1k Views 2 Watching
    • K
      koenvdw
      I just converted to vray 3.4, well I'm testing it.
      I was messing around with the light in the corner. Adjusting te intensity and size.
      When all of a sudden the rendering really got strange.
      As you can see in the picture something is really going wrong and I have no clue whatsoever.
      Anybody that can help?
      Another question. I made a lot of models in v2. When I try to render these I got really big problems with lightning. I can't get the sun or an HDRI to work. Only made lights work.
      Is there something simple to do so that they keep working?
      • filibisF
        filibis
        Are you using GPU acceleration and do you have an AMD graphics card? If so it's not going to work as stated in here:
        Interactive GPU OpenCL rendering mode is currently not supported.
        If you have NVIDIA, try updating your graphics card driver and see if it helps. (Or disable GPU acceleration)
        If you take this scene directly from Vray 2, it might be problematic sometimes. Check this article: Migrating from Previous Versions.
