    DC multiple different OnClick movements
    5 Posts 2 Posters 7.5k Views 2 Watching
    • JQLJ
      JQL
      Hi guys,
      I've been using DC for my arch projects for long. Nowadays just so I can manipulate some elements of my projects with the onclick function.
      I can easily animate a component and that is very handy for showing off some of my stuff to clients or even simply test if some special details are working right.
      However I have the need to animate a component in 2 different ways and can't figure out how.
      Let's say I have a 1m cube. I want to onClick on it:
      1 - once and move it .5m to on the Y axis;
      2 - Click twice and move it 1m
      So far so good. I can do this and revert to the initial position with: AnimateSlow("Movement",0,.5,1) and then set postion with Y=100*Movement
      However I cannot:
      3 - Click the third time and rotate it on the Z axis.
      4 - Click the forth time and it rotates back on the Z axis.
      5 - Click a fifth time and it's back at where it started.
      Is there a easy way to do 3, 4 and then 5?
      If there is a hard way I also don't mind... 😄
      Thanks in advance,
      João
      www.casca.pt
      Visit us on facebook!
      • P
        pcmoor
        this is probably the clearest and most simple, rather than use a load of conditional statements
        source: Jack de Moel
        https://forums.sketchup.com/t/multiple-dynamic-components-w-n-a-dynamic-component/48035/6
        I made a cube as required based on his technique
        cube example.skp
        • JQLJ
          JQL
          Thank you very much Philip!
          I will try and give you feedback.
          www.casca.pt
          • JQLJ
            JQL
            Philip,
            Here's a simple result (click gif):
            You were very helpful! Thank you very much!
            www.casca.pt
            • JQLJ
              JQL
              Philip, I tried the solution you posted above, but ended up using 2 AnimateSlow on a single onClick. I didn't know one could use the semicolon to have double results from one onClick function:
              www.casca.pt
