    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Curve's broken after transformation help!
    5 Posts 2 Posters 1.0k Views 2 Watching
      dohyungkim
      HI! I have a problem while manipulating curves.
      how do I keep my curves in one piece after bending
      In the image below, I have one piece straight lines but as I do group and shape bender my
      curves are broken piece by piece.
      I still need those bended curve for next step.
      In order to have one piece curve again, I have to weld them one by one. too much labor.
      but what if there are tons of broken pieces of curves then how am I weld them.....
      not only shape bender but quite many transforming plugins break up lines
      especially when it ends to something round, curvy.
      Can I get some tip on the issue???
        dohyungkim
        Thanx filibis
        I used 'weld by smustard' before (now I installed superweld? in JHS powerbar) but It still requires handpicking each broken curves to weld selectively
        when I select whole parts including broken part and hit weld,
        sometimes curves mixed up and made weird connections.
        I haven't tried 'removeloneyvertices' yet (where is libfredo6 7.7?? Holy~ can't find anywhere)
        but I got the feeling that it will solve my issue. (will let you know as I get it!)
        thanx again!
        • filibisF Offline
          filibis
          There is also Curvizard plugin which has weld feature (i think better).
          You can double click to curved surface which select all surrounding edges and deselect that you don't need.
          Ignore that plugin, Curvizard or JHS powerbar should be fine. Read carefully what fredo6 writes in his plugin topics (there is a download part).
            dohyungkim
            woooooooooooow!
            this is exactly what I was looking for...
            thanx filibis! I really appreciated!
            I just followed your gif. demo and worked perfect.
            this will save enormous time and effort.
            so I'm just hoping it's got no downside. ha~
            thanx for the help!! πŸ‘
            • filibisF Offline
              filibis
              Check these plugins:
              1- Weld by Smustard Team.
              2- RemoveLonelyVertices by fredo6
