    Best animation process
    7 Posts 3 Posters 938 Views 3 Watching
    • utilerU Offline
      utiler
      Hi guys, just wondering what your preferred plugin / process for animating SU models? I'm keen to start producing some flyovers / walkthroughs for an upcoming job.
      The standard export out of SU is not bad but wanted to consider a more accurate way to do it. Just did a search and found Whaat's 'Smoothstep Animation'plugin and i notice its quite old. Anyone still using it?
      Thanks in advance. πŸ‘
      Just Curious...
        Try Fredo's Animator. Cutting edge πŸ‘
        • F Offline
          faust07
          MSPhysics: put a camera and a target on Curvy Pistons - and action ...
          • utilerU Offline
            utiler
            Thanks fellas,
            @Rich - Don't really need to animate things in the building at all... still the best solution?
            Will have a look at MSPhysics too, cheers @faust07
            Just Curious...
              You can put a placeholder into the scene that would be the camera movement. Then 'attach the camera to that object to create your walkthrough...
                • utilerU Offline
                  utiler
                  NIce. better get learning then...
                  Just Curious...
