    Align object to a line
    18 Posts 5 Posters 5.0k Views 5 Watching
    • hcccsH
      hcccs
      I'm trying to align a piece of tube to a guideline which is at an angle to the X, Y and Z axes. How do I do it in a simple way?
      https://s12.postimg.org/fcgme5tb1/Sku.jpg
        Of course you can with the native "Rotation tool" but it's some painful! ๐Ÿ˜„
          With the Sdmitch one! โ˜€
          Carreful : the axis' components can play on the result! So put them following you wish!
          • Call the Plug
          • Click the Component
          • Click 2 point on the Component
          • Click 2 points anywhere on the Guide line, repeat on the Guide Line for another copy...
            et voilร ! โ˜€
          Here the axes are at the middle bottom of the cylinder
          Click Image for see Animation! ๐Ÿ˜‰
          PS For put easilly axe you can use Axes tools by Thomthom
          • hcccsH
            hcccs
            • Call the Plug
              et voilร ! โ˜€
            [attachment=0:2e106vqd]<!-- ia0 -->GIF_alignComp.gif<!-- ia0 -->[/attachment:2e106vqd]
            [highlight=#ffff80:2e106vqd]What is the name of the plugin? Sam D Mitch has several plugins.[/highlight:2e106vqd]
              The more funny method! ๐Ÿ˜‰
              A little trick with the Perpendicular Face Tool by Chris Fullmer! ๐Ÿค“
              Will be fine for any form! ๐Ÿ˜Ž
              • Draw the Line size of the cylinder length along the Guide Line
              • Take the base Cylinder
              • Call the Plugin
              • Click the extremity wanted on the line
              • Explode
              • Push Pull
              et voilร ! ๐Ÿ˜„
              Other Plugins are existing like Align 3D by Didier Bur
              (more difficult for volumes in any orientation in the space
              because you must draw the start / end 3D help triedre xyz for avoid error)
              but this one above is some easy for any extruded volumes! ๐Ÿ’š
              Add align Component by Sdmitch must be the more easy for any volume! ๐Ÿ˜„
                It was writed! ๐Ÿ˜‰
                • hcccsH
                  hcccs
                  @pilou said:
                  It was writed! ๐Ÿ˜‰
                  [highlight=#ffff00:1tk3c4yp]What exactly do you mean by that?[/highlight:1tk3c4yp]
                    Add align Component
                    That is the name of the script by SDmitch to use! ๐Ÿ˜‰
                    And luckily, it's also the first of the list! โ˜€
                    I can't make more! ๐Ÿ˜ฎ
                    Maybe just to tell you how install a plugin ?
                    Load the plugin, as it's a file ".rb" and you have a Windows System says your profil
                    Compress it for have a ".zip" file (if you have not http://www.7-zip.org/ but use Zip format)
                    Rename the zip file ".zip" in ".rbz"
                    Now From Sketchup Menu Window/ Preferences/ Extensions / Install Extension/ load the
                    "add&Allign Component.rbz"
                    Close SketchUp
                    Re launch SketchUp
                    Plugin will be Menu Plugins (or Extension, I don't remember)
                    SDM Tools / CorG Tool / add&Allign Component ๐Ÿ˜„
                    Have fun Modeling!
                    PS
                    That is more easy method for align any volumes (Components with tricky axis - not only a cylinder)
                    in any alignment in the 3D space to a Guide line or line o 2 clicks in any position in the 3D Space!
                    So a dream for the user! ๐Ÿ˜Ž Just 5 clicks! ๐Ÿค“
                    • hcccsH
                      hcccs
                      @pilou said:
                      Add align Component
                      Close SketchUp
                      Re launch SketchUp
                      Have fun Modeling!
                      [highlight=#ffff00:1o8gz9a7]Thanks Pilou,
                      I have installed it correctly now and reloaded SU and when I click on the object I get a Ding sound so something is obviously wrong. Is the plugin compatible with SU 2017?[/highlight:1o8gz9a7]
                      PS
                        It's because you don't click on a surface of your Cylinder! ๐Ÿค“
                        (and this one must be a Component! )
                        For make a Component
                        Triple-Click (be speed) somewhere on a Volume then Right Click / Make a Component
                        or box selection around the volume in your case a cylinder: Menu Edit / Make a component
                        or a shortcut (if one is existing) when volume is selected
                        If all above is made
                        • Call the Plugin
                          Then the more simple:
                        • Click a surface of your Component
                        • Click start Point on the Guide line
                        • Click another Point on the Guide Line
                          et voilร ! โ˜€
                        Here with a box : so just 3 Clicks (the box is for course a Component)
                        And it axes are like you want (made at the creation of it) !
                        A guide Line is created by the plugin for help you to adjust if wanted!
                        Here the axes are bottom and along an edge!
                        PS
                        For change the Axes of a Component
                        Richt Click on it / Modify Axis
                        Start / End Points can be in the empty space and even not existing!
                        Just make 2 CLicks on the empty Space!
                        A funy and very useful plugin!
                        Bravo to Sdmitch! ๐Ÿ‘
                          And Yes, it's working in 2017! โ˜€
                          Align an object in 3 Clicks in the 3D Space is a task! ๐Ÿ˜Ž
                          Just create tricky Axis of Component following that you wish! ๐Ÿค“
                            You have also Move Along inside FredoTools ๐Ÿค“
                            But it's a little program istself! ๐Ÿ˜‰
                              So...Move along! ๐Ÿ˜„
                              Axis's Cylinder Component are middle bottom
                              but even anywhere Plugin takes middle circle as base cliked!
                              • BoxB
                                You can do it fairly simply without plugins.
                                http://i.imgur.com/O67Onz9.gif
                                • J
                                  Jimnibob
                                  When I align 2 objects (two cubes) to one another so that object 1 is connected to object 2 I am unable to separate them. If I highlight object 1 and try to move it, it distorts the other object it is connected to.
                                  How do I separate the two objects?
                                  • gillesG
                                    gilles
                                    when you create an object make it a group or a component, then it won't interfere with raw geometry (edges faces that are not group or component).
                                    • hcccsH
                                      hcccs
                                      [attachment=0:6j6y05dk]<!-- ia0 -->GIF_move_along.gif<!-- ia0 -->[/attachment:6j6y05dk]
                                      Thanks pilou, "Move Along" did the trick!
                                      • BoxB
                                        You really should only resort to plugins to do such basic things once you can do them manually or you severely limit your understanding of and ability to progress with the software.
