    Noise problem with V-ray 3.40.02 [image attached]
    renderpluginsextensions
    5 Posts 4 Posters 5.9k Views 4 Watching
      laurisarquitetura
      I just updated my sketchup to 2017 and my v-ray to 3.40.02 and all my rendering is coming with a lot of noise.
      All the images get a lot ot of noise. I tried everything, Denoiser, increase render quality, increase image resolution, turn off ambient oclusion and nothing seems to work.
      I Don't know what else to do. Can anyone please help me?
      PS: Im not a professional in rendering. Just an architect trying to work. πŸ˜•
      Thank you.
      Last image i rendered
      • filibisF Offline
        filibis
        Denoiser should fix this easily. Can you share your settings for Denoiser and Global Illumination?
        Check this manual for detailed information about Denoiser.
          laurisarquitetura
          I'll try everything from this manual, it should work. I tried to turn off the progressive renderer setting and increase the min and max subdivs, and it worked a bit. I'll study more. Thank you very much. πŸ‘
          • P Offline
            pinoy
            Try Adjusting Render>Raytrace>noise limit to 0.001 might help.
            • brettsichellodesignB Offline
              brettsichellodesign
              I am getting this same issue only when using Progressive rendering and GPU acceleration.
