    Texture position "pins" in wrong place.
    2 Posts 2 Posters 811 Views 2 Watching
    • E
      elfis
      Hello everyone.
      I'm getting more and more problems with sketchup [After updates].
      I'm using sketchup 2017 with V-ray 3.4.03 i have strange problem with you can see on the image. Texture position pins are in wrong place [X/Y].
      Another problem with textures is when I change texture in vray it's not updating in sketchuup instead I have : V-Ray Texture Helper.png
      Maybe i'm not only one and someone already find solution for this.
      Kind Regards
      Patrick
        I have seen other reports of problems with Vray. Try disabling Vray and see if the behavior in SketchUp improves. You should also get on their forum and see if anyone has a solution.
