    Multiple texture on same face
    3 Posts 3 Posters 876 Views 3 Watching
    • array81A
      array81
      I need to tiling a wall.
      I have to put a decor, so wall tiles are not all the same.
      Can different textures be inserted at different points on the wall?
        Just trim your surface! πŸ˜‰
        PS you have the wonderful plugin FloorGenerator by Sdmitch!
        It can be used for that! πŸ˜‰
        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=57424)
          As Pilou points out you need to split the wall up to paint different faces.
          Afterwards you can use Combine Textures to merge different materials into one material.
