Vray not rendering most of my model
Growing desperate here! Whenever I try to render my model, only part of it shows up. This has happened to me a couple times before but was fixed when I closed Sketchup and opened it again - this time I have done that multiple times, even restarted my computer but nothing seems to be helping. I am attaching how my scene looks on screen and what vray renders - it only renders the wire frames of the chairs. The chairs are from the 3d warehouse and they are components. I also have to point out I have used Thom Thom's cleanup plugin before the render but I am not sure if there is a connection... Any ideas?
Maybe it's grouped too deep. I had a few pieces of render missing when I grouped a group inside a group inside a group etc. Try also resetting to default vray render settings, if you haven't tried it already. What also might be the case is that you have some material ID channel, or some other channel, chosen in Vray frame buffer. In upper left corner, check that. What's strange here is that those chairs on top don't look like the chairs in bottom picture...
Register LoginAdvertisement
