    Chamfer a Hole in a Cylinder
    4 Posts 3 Posters 1.1k Views 3 Watching
    • T
      tricolorturners
      I could use some help with a technique to chamfer the edge of a hole through a cylinder. I cannot seem to make a clean cut using intersect of another cylinder/simulated drill bit. Thanks!
      Thanks,
      Matt
      • cottyC
        cotty
        First would be to work at a bigger scale, have you tried this already?
        my SketchUp gallery
        • T
          tricolorturners
          Thanks. I think it is an alignment issue. I did a separate model where I was able to exactly center everything and it worked fine. The model I am having trouble with already had the hole placed and I have not figured out a good way to align the mock center drill on the hole.
          Regards,
          Matt
            How about uploading a sample SketchUp file showing what you want to do?
