    Vray 3 ruby command to turn off safe region ?
    2 Posts 2 Posters 835 Views 2 Watching
    • E
      elfis
      After many problems with V-Tools2 with I was using in the past I was trying to find solution for saving images with 16/10 aspect ratio. On this forum I found this command with I will use with "custom toolbar". To speed up my work I would like get safe region turned off comand just befere ""Sketchup.active_model.active_view.write_image("D:/filename.jpeg", 1920, 1200)"" and turn back on just after a command.
      Is this even posibble ? fI yes is there anyone can help.
      Thanks πŸ˜„
      • filibisF
        filibis
        You can disable 'Safe Frame' via Asset Editor in Vray 3.
        Asset Editor > Render Settings > Render Output
        Check this out for more info.
