    Need guidance making a cone shape object
    6 Posts 4 Posters 1.0k Views 4 Watching
      Diplomatti
      Hi there, I am very much a beginner at 3D modelling, i only started last year because i got a 3D Printer.
      My dad has asked me to try and make a type of shield for he grass strimmer, a cone shaped item to stop grass from clogging his strimmer.
      This is his drawing of what he would like;
      https://scontent-lhr3-1.xx.fbcdn.net/v/t34.0-12/18679038_10155227966795119_1080648837_n.jpg?oh=734343c03590be0ca3788b59e82fe923&oe=592958B1
      I have tried to make one myself, I've attached it to this post for your amusement.
      Unfortunately, when i slice to model to be printed, it just makes a weird mess really.
      And getting the measurements correct is very difficult to me, because obviously, in the drawing there is no wall thickness, i think 0.8mm would be fine, but i have no idea how i would do that in Sketchup. Also, for some reason i can't explain, the model is at an angle, i have no idea how i managed to do that.
      So if anybody could help me out, either by making a model for me or giving me some guidance on doing what i need, i would be very grateful.
      Cone Shield.skp
        There's lots of ways to tackle this. Try using the Circle tool and Move tool as shown below...
        Click to play...
        • gillesG Offline
          gilles
          FollowMe tool.
            Rich has just forgotten to make a thickness to your object! πŸ’š
            So you can't Print 3D the cone! πŸ€“
            Use the Joint Push Pull by Fredo for that!
              And you will use a cool free real time render (max 1920 * 1080)
              SimLab Composer Light
                Diplomatti
                Wow guys, i wish I'd joined this forum far sooner!
                Thanks to Rich 0 Brien & Pilou Those ideas worked magnificently.
                I didn't use Gilles' method, but thanks very much too for showing another way πŸ˜„
                Edit:
                Finished item
                https://scontent-lhr3-1.xx.fbcdn.net/v/t34.0-12/18741335_10155108127700837_1026135825_n.jpg?oh=a25ee15fa850d0fb3fc794ea6d04919a&oe=5928F0C6
