    What happened to my construction components??
    4 Posts 2 Posters 525 Views 2 Watching
      ScottchUp
      I started working on a framing plan today & noticed that several of the construction components (concrete footings/foundation, framing, etc is no longer there πŸ˜•. Have they been moved to another category? In a hidden file?
      And what, if any, framing plugin do you use/recommend?
        Removed from where? The file or your components library?
          ScottchUp
          From the component library. The "Concrete" and "Wood Framing" components are no longer in the native "Construction" category in the library.
            Doesn't the library no load all items direct from the 3Dwarehouse?
            The Components Sample has some framing objects.
