    Export-Import Scenes Plugin?
    15 Posts 5 Posters 7.0k Views 5 Watching
    • EdsonE Offline
      Edson
      There used to be a plugin for exporting and importing scenes from one file to another. Can anyone remind me which is it?
      Thanks.
      http://www.mahfuz.arq.br
      • HornOxxH Offline
        HornOxx
        I guess you're looking for Eneroth´s Camera Memory which is a great tool 😄
        https://extensions.sketchup.com/de/content/eneroth-camera-memory
        (Unfortunately it does not work with two-point perspectives)
        never trust a skinny cook
        • EdsonE Offline
          Edson
          @hornoxx said:
          I am afraid it is not. I still remember what the other looked like on the menu.
          By the way, how to you put this one to work? I tried and nothing happened. what is the correct workfloe?
          Thanks.
            Before an hypothetic plugin! 😉
            By Riita
            But here is how I managed to copy a model to another project. I just had two SU windows open at the same time. In the other window had the model and the other was empty, so I selected the model and copied it and then pasted it on the other window and so the model was at the same time in two projects. Hope this was what you was wondering "the easier way"?
            • srxS Offline
              srx
              It is like copy-paste camera position.
              This is more what you are seeking http://www.smustard.com/script/PageExIm
              www.saurus.rs
              • EdsonE Offline
                Edson
                will it work with 2017? I wonder. thanks, anyway.
                • F Offline
                  faust07
                  Description : exports and imports camera settings (scenes).
                  Author : Martin Pfirrmann
                  • HornOxxH Offline
                    HornOxx
                    @edson said:
                    ...By the way, how to you put this one to work? I tried and nothing happened. what is the correct workfloe?...
                    Hi - This is how Eneroth´s Camera Memory always works well for me:
                    Before I use "Put to Memory" the source file should be saved, as well as the source scene is updated and saved this way of course as well.
                    I guess that without saving before, the plugin finds nothing which can get stored in it's memory? - but this is only my guess 😕
                    (since I run SU2016, I do not know if it works for SU2017 as well?)
                      File 1 :Scene A,B,D with objects O
                      File 2 : Scene E,F,G with objects P
                      File
                      Create New file 3
                      Does the camera memory can import File 1, File 2
                      for have scene A,B,C, D, E, F with the objects O, P ?
                      • EdsonE Offline
                        Edson
                        it works. thanks.
                        but it is now called Camera Settings Export/Import and its author is Careca. it can be found at the Sketchucation Plugin Store.
                        • EdsonE Offline
                          Edson
                          it works, sort of. what it does is to register the camera position of Scene 1 in file A and transfers it to file B, without saving the scene; this has to be done manually for each scene.. it is better than nothing but it demands a lot of additional work. imagine you have 20 scenes in a file and wants to copy them to another.
                          • EdsonE Offline
                            Edson
                            File
                            Create New file 3
                            hi, Pilou,
                            this kind of extension never imports the objects, just the camera position. and the one we are talking about puts your file in the imported camera position but you still have to create the scene.
                            • HornOxxH Offline
                              HornOxx
                              @edson said:
                              ...it works, sort of... a lot of additional work...
                              you are right 😉
                              somehow I misunderstood scenes as a camera only so I should drink a coffee first 😄
                              https://encrypted-tbn2.gstatic.com/images?q=tbn;ANd9GcTc3IuDvQBV_5yeU4u9rfbe66cDTxnW8135pFlXdRdUPvqE6oMI
                                About
                                http://www.crai.archi.fr/RubyLibraryDepot/Ruby/pageExIm.rb by Rick Wilson
                                pages = scenes
                                Me
                                Est-on bien en droit d'attendre, par exemple, que cela ajoute des pages "exportées" à une animation existante?
                                Didier Bur
                                Ben oui, c'est ça l'idée!
                                In English 😄
                                Me : Can we expect , for example, add exported pages to an existing animation?
                                Didier Bur
                                Of course, that's the idea!
                                But seems the "Pages Export" don't work! 😲
                                File "*.su" is not created! (array_to.rb is installed)
                                It's the same for you ?
                                • EdsonE Offline
                                  Edson
                                  @pilou said:
                                  About
                                  pages = scenes
                                  Me
                                  Didier Bur
                                  In English 😄
                                  Didier Bur
                                  PageExIm used to work fine for me but I think it has been updated to work with 2017.
                                  EDIT: I have just checked the Smustard website and PageExIm HAS been updated for 2017. Sorry!
