    Vray Materials
    renderpluginsextensions
    2 Posts 2 Posters 2.0k Views 2 Watching
    • S
      Suzidar87
      I used sketch up with vray a few years ago, and haven't has the need to use it since until now. I am currently running sketch up make 2016 and have purchase vray 3.4.
      I am quite confident with using sketch up, but I am unsure of how to use the vray materials. From memory there use to be a vray materials library with glass, grass, metal, wood presets which worked better within the model when it was rendered. However the version of vray I am using does not seem to have a materials library?
      On the chaos group webpage it says there are 520 materials with the version I have, but how can I use these within sketchup?
      Or do these have to be downloaded from an independent website?
      Thanks in advance.
      • filibisF
        filibis
        Check this manual out: https://docs.chaosgroup.com/display/VRAYSKETCHUP/Preset+Material+Library
