    Glass displacing the interior - help fixing
    renderpluginsextensions
    2 Posts 2 Posters 877 Views 2 Watching
      apple85
      I've just tried to do a really rough test render with vray (just a straight click and render - just used default setting) and noticed that the glass windows are really displacing the interior.
      The first image is the image on sketch, second is the vray render and third I deleted a couple of the window glass panels that identified the problem.
      Could someone have a look at the attached images and have a guess of what may of happened as it looks really unnatural.
      (It doesn't do this at all angles of the model I've noticed - this seems to be the problem angle)
      • P Offline
        peerman
        Give the glass some thickness or set the refraction to 1.0.
        Best,
        iMac i7 4,2GHz, 32GB RAM, OS X 10.13.5, Sketchup 2018 Pro, ArchiCAD 21, V-Ray 3.6
