    Double-Cut - Cut through double-sided walls
    extensions
    44 Posts 19 Posters 21.8k Views 19 Watching
    • W Offline
      Whaat
      Just want to announce our new plugin Double-Cut for cutting through double-sided walls. Thomthom had been pursuing this plugin many years ago and he was kind enough to let me use his plugin name since he is not working on it anymore. Thanks Thom!
      Available for purchase here (SU2017+ only):
      http:https://mindsightstudios.com/double-cut/
      15 Day Free trial also available
      • pbacotP Offline
        Great exciting music.
        (Oh and did I say the plugin looks AWESOME!!!!!!)
        Thank you, Thank you, Thank you!
        • JQLJ Offline
          JQL
          Ole!
          www.casca.pt
          Visit us on facebook!
            A VisuHole + Components! 😎
              Minute 0.27 - 0.38 is yet "double cut" ?
              • PixeroP Offline
                Pixero
                Wow. Looks great. Another must have plugin.
                • jujuJ Offline
                  juju
                  Will this work on cavity walls (multi layered walls) and complete the returns / reveals?
                  • W Offline
                    Whaat
                    Sorry, it just works inside the 'active' wall group. If the wall is multi-layered and each layer is a separate group, it won't work for that.
                    • andybotA Offline
                      andybot
                      Ahhh, sigh of relief! This is something I've been imaging should be possible for about as long as I've been using sketchup. Great work, can't wait to try it!
                      • Bob JamesB Offline
                        Bob James
                        Instant buy for yet another "must have" tool. Many thanks. 👍 👍
                        • PixeroP Offline
                          Pixero
                          A question.
                          If I use this plugin in a model and someone that doesn't have this opens the model and moves a window. What happens?
                            rv1974
                            I'll buy X10 if it works on curved surface.
                            P.S. Any plans for PB refreshing?
                            • W Offline
                              Whaat
                              @pixero said:
                              A question.
                              The window will move but the hole created from Double-Cut will not move unless you 'unlock' it with the Right-click context menu and move it manually with the SU move tool.
                              • W Offline
                                Whaat
                                Sorry, the tool is not designed for curved surfaces. Basically, the tool extends the existing functionality of SketchUp's cutting components. Since SketchUp's cutting components don't work on curved surfaces, DC won't work either.
                                • brettsichellodesignB Offline
                                  brettsichellodesign
                                  I'm having some trouble with this plugin. Please see attached video. My door component doesn't seem to want to cut through the wall.
                                  • W Offline
                                    Whaat
                                    The axis of your door needs to be set correctly. You also need to make sure your component has a closed loop of edges on the same plane as the x-y plane of your component. Check out this tutorial on creating cutting components.
                                    SketchUp: Creating Cutting Components
                                    As my first How To post, here is a method of creating a component that cuts through a surface. Here are a few things to keep in mind Although you can activate the cutting feature on an existing component, it can become…
                                    SketchUp Community (forums.sketchup.com)
                                    • utilerU Offline
                                      utiler
                                      Cool plugin, Dale!! Something that has been on the request list for soooo.... long!!
                                      Just thought I'd make everyone aware that are using Skalp that it won't cut around openings as the standard SU section cut tool does. Not sure why; I'll ask the question of the Skalp team and see what they say.
                                      Just Curious...
                                      • srxS Offline
                                        srx
                                        This is because the wall is not a solid. Faces on the side belongs to window group I guess.
                                        www.saurus.rs
                                        • utilerU Offline
                                          utiler
                                          Whether its a solid or not surely the skalp tool should be able to work similar to the SU native tool??
                                          Just Curious...
                                          • srxS Offline
                                            srx
                                            SU native tool doesn't make faces inside the wall.
                                            www.saurus.rs
                                            • 1 / 3
