    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    How to remove components folder from Favorites?
    14 Posts 4 Posters 3.7k Views 4 Watching
      blackdogsketch
      Somehow, a few of my folders in Components\Favorites have become corrupted; they point to other folders. If I try to delete when the folder is active, the "Remove from Favorites" option is grayed out. If I click it, and get sent to the wrong folder, and then try to delete...the "Remove from Favorites" option then deletes the good folder.
      There does not seem to be any way to organize and edit the folders once they are "Added to Favorites"
      (All my local components are in folders, by division, on my Dropbox)
      Any suggestions?
        First, it's not recemmended to use Dropbox as your "local collection" location. This will create problems for you.
        Second, try creating folders with the names shown as favorites in the wrong location and see if they override the existing ones. You might need to edit the registry to get SketchUp to remove the favorites altogether and then start over.
        there are other threads here on SCF related to this. Search 'delete favorites'.
        What version of SketchUp are you using? Is your profile current on that?
          blackdogsketch
          Thanks Dave
          What is problematic about dropbox storage? It has worked pretty well for about five years. Do you think this sort of thing is a result of dropbox storage?
          I'm on 2016 Pro. Not sure about "my profile". Don't recall messing with that.
          Not sure how to edit registry either.
            The sort of thing you report is one problem with using DropBox or other cloud storage. Another commonly reported issue is failure to save because access/write times are too long. The general wisdom (and recommendation from the SketchUp team) is to keep files on a local drive. Dropbox is not local. If you need access to the files from another location, sync the dropbox folder to your local folder.
            Editing the registry is not to be taken lightly.
            Do this first: Copy the folders from Dropbox to your hard drive. Then remove them from Favorites allowing SketchUp to remove the ones from Dropbox. Then add the local folders on your hard drive to your favorites.
            Please update your profile, too. It shows you are using SU8. Showing the correct version is useful to others when trying to provide you with assistance.
            • Bob JamesB Offline
              Bob James
              Slightly off topic
              How about storing all folders on a NAS drive: would that be fast enough for my laptop and desktop?
                It probably would be, Bob. Are you connecting directly via Ethernet or USB? I think it would be worth a try.
                  Bob James
                  Hardwire Ethernet network.
                    I expect it would be fast enough. Your homework is to try it and report the results. ๐Ÿ˜„
                      blackdogsketch
                      Thanks Dave. Will do. Have not been able to remove anything from favorites so far.
                        blackdogsketch
                        I have tried deleting all favorites. there are about six problematic ones where it appears a link has been broken. When those are selected, the option of Remove from Favorites is grayed out.
                        If I click on a valid Favorite folder, it brings up the template of components. If I then click on one of the problematic folders, the display of components remains the same (the previous set) and if I "Remove from Favorites, it deletes the good one but not the problematic one.
                        Confused. It appears that I just cannot delete these last six.
                          blackdogsketch
                          So I left the six nonfunctional links there. And added all the favorites from what is now a local folder. Checking thru them all...got thru the first six or so...and links were valid. then, as I selected other folders, the display of components menu remained the same...in other words, it doesn't change when I select new folders. And then go back thru the fist several, and not of those are functioning now either. Essentially, loading them all new from a local folder has made this a 100% problem instead of a 25% problem.
                          Any advice would certainly help. I'm out of my depth on this.
                            dwaynelord
                            2021... many years later. bug still exists. one thing that is consistent with SketchUp is that they really don't fix known issues. sure would like to delete some of these "non-existent" favorite component directory. instead I get to look at them over and over know they don't exist and I can't delete them because sketchup has had this bug for years...
                              It's actually 2022.
                              @dwaynelord said:
                              bug still exists.
                              No. It doesn't.
                              Click on the picture.
                              That's untrue.
                                dwaynelord
                                Actually it is quite true.
                                I have favorite component directories that I can't delete. No option... Still a bug. If the directory no longer exists we should be able to delete it from favorites. Period. Having them persist and junk up the list is a bug.
                                And yes Sketchup has other bugs they have not addressed. For instance the use of "/u" in directory file paths that breaks dynamic components. Pretty much makes dynamic components useless for anyone on windows who uses the "/Users" file directory, which is most everyone...
                                That bug has also been around for years...
