    Auto Length
    7 Posts 3 Posters 2.6k Views 3 Watching
    • K
      koliboti
      Hi, is there a plugin that puts/writes automatic the length of a solid group on the groups surface?
      I have many lumbers and I need to write the length of them...
      • P
        pcmoor
        You could add a dimension within the component aligned with the face. Dimensions can be tweaked via the window/model info menu, select dimensions.
        If you create a board component then you can scale to any other size by entering the measure followed by the units
        To create a board where the material is not stretched after scaling, right click an make unique, and then right click and scale definition
        Further more one can add a tag in the dimension followed by <> this will create a named item followed by the dimension
        tagged with board...
          You have this fabulous free plugin ( I don't know if existing in English)
          Cotations are minutes 6.06
          or maybe this other one πŸ˜„
          • K
            koliboti
            Thank You Pilou for the suggestion! The packing plugin is seems to be fantastic, but is says me this:
            Aucun composant en panneau.
            All elements are solid components...
              First
              You must create with plugin Piece each component(s) ! (don't forget to change Name between each) !
              Any dimension X, Y, Z , any name... Green dimension will be the thickness of the big slab!
              Then run Packing! πŸ˜‰(no need to select something! )
              For example πŸ˜„
              As there is no same tchickness of material there are different scenes with same material!
              • K
                koliboti
                Thank You Very Much Pilou!
                The secret is that all elements is must be created with the BLB plugin. πŸ˜„
                • K
                  koliboti
                  Perfect solution for multiple dimensions: Auto magic dimensions plugin by Brighter3D.
