    SketchUp automatically applied a texture to the backfaces
    10 Posts 4 Posters 1.8k Views 4 Watching
    • ken28875K Offline
      ken28875
      Hello,
      I had this problem before but it somehow disappeared.
      It now appears again. SketchUp will automatically applied a texture from the model to the back faces of any geometry I create.
      I used Remove All Backface Materials from Thomthom's Material Tools, but it did not work.
      Any suggestion on how to fix this?
      Thank you!
      _KN
      Follow Your Dreams.
      • JQLJ Offline
        JQL
        That's strange. It applies to the back but not to the front?
        Can you share a model?
        www.casca.pt
        Visit us on facebook!
        • ken28875K Offline
          ken28875
          Hi JQL,
          It does apply to the front faces, but also add the texture to the back face without haveing me to click on it.
          Ok, I just found out how to fix it but don't know the cause of it. This issue happens with components. So when I explode the component, the problem is gone. SketchUp uses the normal colors for front and back faces without automatically applies a texture used in the component.
          Best,
          _KN
          Follow Your Dreams.
            Does the material have Opacity set less than 100. If opacity is set to anything less than 100 the material gets applied to both sides of the face. This isn't a bug and it makes sense when you are applying a material that should be transparent. It does look strange when the material is a brick pattern or something else that normally isn't transparent.
              Weird. Can you share the material? Or a model in which it happened?
              • ken28875K Offline
                ken28875
                Hi Dave,
                The material has 100% opacity.
                Don't know why, but the problem happens only inside the component. When the component is exploded, the faces are normal, showing the correct colors of front/back faces.
                Thanks,
                _KN
                Follow Your Dreams.
                • JQLJ Offline
                  JQL
                  If a component has a material applied that material always overrides the default material both on back and front faces.
                  www.casca.pt
                  • pbacotP Offline
                    I like JQL's answer, but it seems too obvious. Still I had this one bugging me before and it took a while to see the problem and fix it.
                    • JQLJ Offline
                      JQL
                      Sometimes it's in front of us and we don't see it...
                      www.casca.pt
                      • ken28875K Offline
                        ken28875
                        Thanks, JQL, you may be right. Have a good weekend! πŸ˜‰
                        Follow Your Dreams.
