    Object Information not Updating
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    2 Posts 2 Posters 7.0k Views 2 Watching
    • J
      Jbennette30
      I'm having and issue where I cant seem to get animator to accept changes made to a component axis orientation. I changed the axis after realizing that i was trying to screw the component around the Z axis and that the axis what not centered to the component. Basically I cant get animator to accept this change to the model.
      Any suggestions or even a redirect is appreciated.
      SU 2016
      Fredo library v7.5b (deleted old folder and installed fresh)
      Animator v1.5a
      Here is a view of the Component axis in Animator's view and SU native
      • fredo6F
        fredo6
        The Z axis seems to be correct.
        I think you may be referring to the center. Screw uses the component center to position the axis of rotation.
        On the picture, it seems your component is symetrical along the Z axis. So if the translation direction is the Z axis, then it should screw normally.
        Anyway, the best would be to post your model, so that I can have a closer look.
        Fredo
