    Scale partially!
    6 Posts 2 Posters 1.2k Views 2 Watching
    • M
      miker-gr
      Hello everybody!
      I want to scale a plan but i need only the external perimeter to extent
      There are also internal part that i only want their position to change and not their size. Can i do it in sketchup?
        It would be easier to give you an exact answer if you shared the SKP file. Most likely you can modify the dimensions by using the Move tool instead of Scale.
        • M
          miker-gr
          It's a pattern and i want to make different sizes
            OK. You can do that.
            • M
              miker-gr
              How can i make the inner part to keep their size stable and chage only their position?
                Use the Move tool to move just what needs to be changed.
