    Importing SU colours into LO
    layout
    13 Posts 6 Posters 3.4k Views 6 Watching
    • utilerU Offline
      utiler
      Ok, maybe another D'oh! moment here....
      I've created a colour sampler of pastels in SU based on this image:
      and want to use it in LO as well.
      I thought I'd be able to import the model and explode it to get colour values but NOOOO!!!!
      Does anyone knowhow to other than setting it up manually in LO?
      Just Curious...
      • jujuJ Offline
        juju
        Have you tried making a scrapbook with each of the items made separate groups, and not grouping all?
        • utilerU Offline
          utiler
          Thanks juju, what I'm asking is there a way to bring in SU colours into LO. exporting the SU file to LO and making a scrapbook file doesn't make any difference... even if you explode the file.
          Just Curious...
          • JQLJ Offline
            JQL
            I'm thinking of a workaround:
            1 - Add Bitmap to Mats (plugin);
            2 - Export material textures to folder (there's a plugin for that too, that I've seen around);
            3 - Use that folder in LO by creating a custom pattern fill collection.
            If you don't find the plugins, shout, that I will help you search for them.
            www.casca.pt
            Visit us on facebook!
            • bazB Offline
              baz
              Can't you use the eyedropper tool in LO to sample the colour?
              Or am I missing the point?
              • bazB Offline
                baz
                Try exploding the 'Vector' model in LO and ungroup until you just have the colour swatches.
                Does that get you what you want?
                SU model exploded & ungrouped, all but faces deleted
                  Creating a scrapbook of the color swatches ala Baz is a good way to manage it.
                  Another way would be to export an image of the colors from SU and choose that image in the Colors inspector window in LO.
                  • utilerU Offline
                    utiler
                    [attachment=0:x9yzousc]<!-- ia0 -->colour swatch test.JPG<!-- ia0 -->[/attachment:x9yzousc]
                    That is what I was trying to do, Baz. Cheers!! Didn't think to convert to vector first....
                    Thanks to you, Dave and JQL for your input as well. Really appreciate it. πŸ‘ πŸ‘
                    Just Curious...
                    • bazB Offline
                      baz
                      πŸ‘
                      • utilerU Offline
                        utiler
                        Just revisiting this thread; when converting colours to vector and exploding down to base elements, any colours with opacity levels altered will come in as full colour.
                        Just Curious...
                        • bazB Offline
                          baz
                          That is just a condition of vectorizing the file. Same as when you lose shadows etc.
                          You can get your opacity colours in hybrid or raster. But with less editing capabilities.
                          But then you are back where you started I suppose.
                          • utilerU Offline
                            utiler
                            Here's the LO file for any of you who want to use it.... thanks for all your input, guys.
                            PASTELS.layout
                            Just Curious...
                            • RichardR Offline
                              Richard
                              You could then just reapply the opacity level, though I'd be inclined to change the mode of the colour editor and add white.
                              BUILTBRAND.COM.AU
