    Medeek Wall Plugin
    1.6k Posts 29 Posters 1.9m Views 28 Watching
    • gullfoG Offline
      gullfo
      maybe collapse the wall sheathing section as well so it's only opened if you need to edit it.
      Glenn
      http://www.runnel.com
      • medeekM Offline
        medeek
        Version 3.3.6 - 11.18.2023
        • Added a "Menu UI" parameter in the General tab of the Global Settings with the following options: Legacy, Collapsed, Expanded.
        • Updated the Wall Draw and Edit menus with the new Menu UI options.
        • Fixed a bug with the tee intersection algorithm for rectangular "stacked" walls.
        The additional menu options are in response to feedback from multiple users requesting a less busy and simpler menu system. By default the legacy menu system is selected in the global settings however one can quickly change to one of more advanced "collapsible" systems. This is my first real crack at this so further refinement may be necessary depending on the feedback I receive.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM Offline
          medeek
          Tutorial 45 - Menu UI Options (8:08 min.)
          design.medeek.com
          • medeekM Offline
            medeek
            Version 3.3.7 - 11.20.2023
            • Fixed a bug with the hotkey (Up key) for wall panelization in the Draw Wall Perimeter tool.
            • Fixed a bug with the Draw Wall Perimeter tool for metric units.
            !!!! Critical Bug Fix !!!!
            This is a critical bug fix for users of metric units. I highly recommend upgrading to this latest version for all users.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.3.8 - 11.22.2023
              • Added two additional parameters for annotation formatting.
              • Added the "Regen Electrical" function to the primary toolbar, enabled regeneration for all electrical fixtures.
              • Moved the "Draw Safety Device" tool to the secondary toolbar.
              http://design.medeek.com/resources/electricalplugin/images2/elec_su237_800.jpg
              http://design.medeek.com/resources/images/electrical_su_menu_active.jpg
              http://design.medeek.com/resources/images/electrical_ii_su_menu_active.jpg
              design.medeek.com
              • medeekM Offline
                medeek
                Version 3.3.7b - 11.27.203
                • Fixed a critical bug introduced with Version 3.3.6.
                !!!! CRITICAL BUG FIX !!!!
                This is a critical bug fix for all users, please download the latest version of the plugin (3.3.7b).
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 3.3.8 - 12.02.2023
                  • Updated the face selection algorithm of the draw wall perimeter tool.
                  This addresses the issue of selecting faces that are embedded or nested within groups. You can now select faces that are in the root of the model or nested within other groups.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 3.3.9 - 12.18.2023
                    • Added a "Cedar Siding" built-in material (horizontal) into the material library.
                    http://design.medeek.com/resources/wallplugin/images6/wall_su723_800.jpg
                    This material is a horizontal version of the previously added vertial version. This update per customer request.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 3.4.0 - 12.22.2023
                      • Fixed a minor bug with the error checking code for custom casing profiles of windows and doors.
                      • Added top and bottom vertical offset parameters for shearwall sheathing.
                      • Added a QHQ casement window to the window draw and edit modules.
                      http://design.medeek.com/resources/wallplugin/images6/wall_su725_800.jpg
                      http://design.medeek.com/resources/wallplugin/images6/wall_su726_800.jpg
                      Both updates are per customer request.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 3.4.1 - 12.29.2023
                        • Updated and improved the license verification module.
                        • Disabled redundant logging to improve plugin performance.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 3.4.2 - 01.09.2024
                          • Fixed a bug with steel framing and tee intersections.
                          • Fixed a bug with hip walls and tee intersections (two stud with blocking).
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 3.4.3 - 01.18.2024
                            • Improved the serial number verification logic within the License tab of the Global Settings.
                            • Added a Door Reset button in the Doors tab of the Global Settings.
                            • Added a Window Reset button in the Windows tab of the Global Settings.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 3.4.4 - 01.24.2024
                              • Added a pressure treated option for in-wall columns.
                              • Created a more realistic material/texture for pressure treated timbers (for in-wall columns and posts).
                              http://design.medeek.com/resources/wallplugin/images6/wall_su727_800.jpg
                              design.medeek.com
                              • gullfoG Offline
                                gullfo
                                one thing i recently ran into was needed a steel column to support a steel beam spanning a couple of walls to get the proper support for ceiling joists. it would be a nice option (not necessarily to provide a steel column in leiu of a wood one πŸ˜„ ) but just to leave the space for easily adding one separately (and thus avoiding closing it etc when regenerating due to a wall change).
                                cheers!
                                Glenn
                                • medeekM Offline
                                  medeek
                                  I could provide another option in the Advanced Options section which essentially removes the column and leaves a blank opening in wall. Is this what you are suggesting?
                                  design.medeek.com
                                  • gullfoG Offline
                                    gullfo
                                    yes, or even just have a column type of "blank" (or simply marker) in the selection list (along with x dia round steel, x by x wood, etc) πŸ˜„ this way the code is effectively the same, just whether or not the spacing has anything other than say a 2D marker of the column location.
                                    Glenn
                                    • medeekM Offline
                                      medeek
                                      Version 3.4.5 - 01.28.2024
                                      • Added two additional column types for in-wall columns: Custom, Blank.
                                      • Three additional parameters added for custom in-wall columns.
                                      • Added a custom label option and annotation section for in-wall columns.
                                      • Updated the javascript logic within the License tab of the Global Settings.
                                      http://design.medeek.com/resources/wallplugin/images6/wall_su728_800.jpg
                                      Technically this update is a bit redundant because one can already configure custom in-wall columns within the global settings. However, this new option gives one the ability to insert any sort of column into the wall (non-wood) as well as a blank opening where one could then insert their own manually modeled column or structural support.
                                      The custom label option applies to all column types, so it can override the auto labeling algorithm of the module.
                                      design.medeek.com
                                      • gullfoG Offline
                                        gullfo
                                        thanks! this will be handy as i design a lot of studio where the isolation structure has to be separated from the exterior and custom columns and sizing it for that critical 2" separation, using i-beams and glulams, when using autogenerated walls etc will make this much easier to draw and document πŸ˜„
                                        Glenn
                                        • medeekM Offline
                                          medeek
                                          Version 3.4.5b - 01.28.2024
                                          • Fixed a bug with holdowns for in-wall columns.
                                          • Fixed a bug with the bottom plate cutting algorithm for in-wall columns.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 3.4.6 - 01.30.2024
                                            • Added a "Dimension to Centerline" option for framing dimensions in the General tab of the Global Settings.
                                            • Enabled centerline dimensioning for openings, columns and SSW for rectangular walls.
                                            • Added a "Style 5" (Pull Plate) to the built-in door hardware options.
                                            • Added more options for grid style window grilles: 3X4, 4X5, 5X6.
                                            http://design.medeek.com/resources/wallplugin/images6/wall_su730_800.jpg
                                            http://design.medeek.com/resources/wallplugin/images6/wall_su729_800.jpg
                                            http://design.medeek.com/resources/wallplugin/images6/wall_su731_800.jpg
                                            All updates per customer requests.
                                            design.medeek.com
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 80
                                            • 81
                                            • 67 / 81
