    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.0m Views 28 Watching
    • medeekM
      medeek
      Tutorial 43 - Opening Tool (6:01 min.)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 3.3.5 - 11.09.2023
        • Added the Copy Opening Tool to the Medeek Wall Tools II toolbar.
        • Enabled the Copy Opening Tool for Windows, Man Doors and Garage Doors.
        • Enabled subtractive geometry for Beam Assemblies.
        • Added additional W-Flange steel beam sizes.
        http://design.medeek.com/resources/images/wall_tools2_su_menu_active.jpg
        design.medeek.com
        • medeekM
          medeek
          Tutorial 44 - Opening Copy Tool (4:45 min.)
          design.medeek.com
          • medeekM
            medeek
            I will be running a Thanksgiving promotion beginning Nov. 12th until Dec. 1st. with 40% off of the regular mdkBIM bundle price (permanent license) using the coupon code GIVETHANKS23.
            This will reduce the bundle price from $280.00 USD to $168.00 USD. This promo code does not apply to any of the extensions purchased separately or for the electrical plugin. The offer ends on Dec. 1 and no rain checks will issued thereafter.
            Medeek Design Inc. - Garage, Shop, Shed and Barn Plans
            (design.medeek.com)
            https://global.discourse-cdn.com/sketchup/original/3X/7/e/7e084d84a01860096ecb19d2a23a6ef8937179c3.jpeg
            design.medeek.com
            • medeekM
              medeek
              First look at my attempts to simplify the look and feel of the Draw and Edit menus for walls:
              https://global.discourse-cdn.com/sketchup/optimized/3X/3/f/3fcfa13f26c1462c19ba81a6303a8e5d7170b1e8_2_633x500.jpeg
              https://global.discourse-cdn.com/sketchup/original/3X/c/e/cec8d04e4467e2c59ac4892a7df20b91ae8ace49.jpeg
              I'm no UI expert but my idea is to create collapsible menus for certain sections that are not modified as commonly during regular use. The "wall start" and "wall end" sections are a good examples of such sections. Typically the parameters within these two sections are only modified in certain specific situations or when customization is required.
              Thoughts?
              design.medeek.com
              • medeekM
                medeek
                After shuffling things around a bit:
                https://global.discourse-cdn.com/sketchup/original/3X/9/f/9fad44c6635b574b22ddd03fedfce1e6376324bb.jpeg
                https://global.discourse-cdn.com/sketchup/original/3X/7/2/72e7043b13ebaefed5d51934f0261e3aafbc5831.jpeg
                I've created a new section for framing options/details. Notice that in this section I've also moved the stud removal parameter, which was formerly in the advanced options (I think it makes more sense to place it in this section).
                The advanced options section is unchanged and still very busy with a ton of parameters but I really don't know what to do about it since all of those advanced options are necessary and need to be placed somewhere. (If you disable the Advanced Wall Options then that whole section is not shown.)
                So currently, with the new UI update so far, there are three sections that can be toggled by the user manually. I should probably also add into the global settings some parameters which will control the default visibility for these sections.
                design.medeek.com
                • gullfoG
                  gullfo
                  maybe collapse the wall sheathing section as well so it's only opened if you need to edit it.
                  Glenn
                  http://www.runnel.com
                  • medeekM
                    medeek
                    Version 3.3.6 - 11.18.2023
                    • Added a "Menu UI" parameter in the General tab of the Global Settings with the following options: Legacy, Collapsed, Expanded.
                    • Updated the Wall Draw and Edit menus with the new Menu UI options.
                    • Fixed a bug with the tee intersection algorithm for rectangular "stacked" walls.
                    The additional menu options are in response to feedback from multiple users requesting a less busy and simpler menu system. By default the legacy menu system is selected in the global settings however one can quickly change to one of more advanced "collapsible" systems. This is my first real crack at this so further refinement may be necessary depending on the feedback I receive.
                    design.medeek.com
                    • medeekM
                      medeek
                      Tutorial 45 - Menu UI Options (8:08 min.)
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 3.3.7 - 11.20.2023
                        • Fixed a bug with the hotkey (Up key) for wall panelization in the Draw Wall Perimeter tool.
                        • Fixed a bug with the Draw Wall Perimeter tool for metric units.
                        !!!! Critical Bug Fix !!!!
                        This is a critical bug fix for users of metric units. I highly recommend upgrading to this latest version for all users.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 1.3.8 - 11.22.2023
                          • Added two additional parameters for annotation formatting.
                          • Added the "Regen Electrical" function to the primary toolbar, enabled regeneration for all electrical fixtures.
                          • Moved the "Draw Safety Device" tool to the secondary toolbar.
                          http://design.medeek.com/resources/electricalplugin/images2/elec_su237_800.jpg
                          http://design.medeek.com/resources/images/electrical_su_menu_active.jpg
                          http://design.medeek.com/resources/images/electrical_ii_su_menu_active.jpg
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 3.3.7b - 11.27.203
                            • Fixed a critical bug introduced with Version 3.3.6.
                            !!!! CRITICAL BUG FIX !!!!
                            This is a critical bug fix for all users, please download the latest version of the plugin (3.3.7b).
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 3.3.8 - 12.02.2023
                              • Updated the face selection algorithm of the draw wall perimeter tool.
                              This addresses the issue of selecting faces that are embedded or nested within groups. You can now select faces that are in the root of the model or nested within other groups.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 3.3.9 - 12.18.2023
                                • Added a "Cedar Siding" built-in material (horizontal) into the material library.
                                http://design.medeek.com/resources/wallplugin/images6/wall_su723_800.jpg
                                This material is a horizontal version of the previously added vertial version. This update per customer request.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 3.4.0 - 12.22.2023
                                  • Fixed a minor bug with the error checking code for custom casing profiles of windows and doors.
                                  • Added top and bottom vertical offset parameters for shearwall sheathing.
                                  • Added a QHQ casement window to the window draw and edit modules.
                                  http://design.medeek.com/resources/wallplugin/images6/wall_su725_800.jpg
                                  http://design.medeek.com/resources/wallplugin/images6/wall_su726_800.jpg
                                  Both updates are per customer request.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 3.4.1 - 12.29.2023
                                    • Updated and improved the license verification module.
                                    • Disabled redundant logging to improve plugin performance.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 3.4.2 - 01.09.2024
                                      • Fixed a bug with steel framing and tee intersections.
                                      • Fixed a bug with hip walls and tee intersections (two stud with blocking).
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 3.4.3 - 01.18.2024
                                        • Improved the serial number verification logic within the License tab of the Global Settings.
                                        • Added a Door Reset button in the Doors tab of the Global Settings.
                                        • Added a Window Reset button in the Windows tab of the Global Settings.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 3.4.4 - 01.24.2024
                                          • Added a pressure treated option for in-wall columns.
                                          • Created a more realistic material/texture for pressure treated timbers (for in-wall columns and posts).
                                          http://design.medeek.com/resources/wallplugin/images6/wall_su727_800.jpg
                                          design.medeek.com
                                          • gullfoG
                                            gullfo
                                            one thing i recently ran into was needed a steel column to support a steel beam spanning a couple of walls to get the proper support for ceiling joists. it would be a nice option (not necessarily to provide a steel column in leiu of a wood one 😄 ) but just to leave the space for easily adding one separately (and thus avoiding closing it etc when regenerating due to a wall change).
                                            cheers!
                                            Glenn
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 80
                                            • 81
                                            • 67 / 81
