    Bathroom this time
    15 Posts 5 Posters 1.5k Views 5 Watching
    • Bryan KB Offline
      New 3D design and render. This one I designed. Didn't spend a lot of time or thought on this one. Just grabbed the fixtures and brick-a-brac I liked from the 3D Warehouse and then built the bathroom.
      Walls, floors, sink counter, lighting, and outdoor background are mine. Those ARE two windows at the back and not open doorways. The louvered door is to the water closet.
      Again, click on image for sharper image.
      I am loving Raylectron.
      Final render farther down.
      VVV
      • Bryan KB Offline
        Brightened the lighting a little bit.
        • pbacotP Offline
          Nice renders. I like the tub deck concept. Least favorite part is the outdoors. Doesn't look as real as the rest.
          • Bryan KB Offline
            Thanks pbacot!
            Yeah, that foliage gave me fits. The outdoor lighting is also not quite right and the raked sand is bleh. I need to work on it.
            • Bryan KB Offline
              Again, thanks for the suggestion pbacot. Hope this looks better. I certainly like it better.
                joewood
                So what the dimensions of this room? 10' ceilings?
                ...... joe
                • Bryan KB Offline
                  ...... joe
                  9ft ceilings. 11ft wide by 13ft long. It's pretty big. The water closet has both toilet and bidet.
                    Nice, the exterior is much better. Possibly a bit more shine on the tub.
                      mwm5053
                      Nice Bryan
                      2011 iMac
                      SU 2015 Pro, 2017 Make
                      V2 Twilight
                      macOS Sierra 10.12.5
                      • Bryan KB Offline
                        Thanks Mike.
                        Yeah, the tub needs some work. I also think I've got the outdoor lighting a little too bright. Not much, but I'll knock it down a tiny bit and see if that makes a difference.
                        • Bryan KB Offline
                          @mwm5053 said:
                          Nice Bryan
                          Thanks Walt.
                          I feel I'm having really good success with Raylectron. The UI seems to suit me. Render times aren't bad either. This one is taking about 20 min on my 5 year old laptop and I stop it at 200 sample/passes.
                          • Bryan KB Offline
                            Well the tub won't go real shiny. I doubled the shiny on that material. I think it's due to the overall lighting of the bathroom. I did knock down the outside sunlight and it looks better, but it's very subtle.
                            So here's the very last one and I'll do better on my next model. 💚
                            Thanks again for everyone's suggestions and compliments.
                            • pbacotP Offline
                              The outdoors looks nicer!
                              • pbacotP Offline
                                @bryan k said:
                                Thanks Mike.
                                I can see you want to show off that wall, but the bright sunlight would, in reality, create a huge glare in contrast with the interior. So yes, maybe less brightness would be fitting.
                                • Bryan KB Offline
                                  Thanks pbacot. 👍
