    Sketchup 2017 snap to axis BUG
    3 Posts 3 Posters 7.9k Views 3 Watching
    • N Offline
      NfSC31
      Hello,
      i have a problem. Sometimes Sketchup 2017 stops snapping to axis. Thing is he stops snap to some of axis, for example now he snaps only to green axis, he doesn't see blue and red. I open clean file, draw models and suddenly it happens.
      It is so annoying, i must restart Sketchup all the time so snap to axis work again. πŸ˜• πŸ˜• πŸ˜•
      • P Offline
        peerman
        Hi have the same problem here as well...
        Running macOS, could that be it?
        iMac i7 4,2GHz, 32GB RAM, OS X 10.13.5, Sketchup 2018 Pro, ArchiCAD 21, V-Ray 3.6
          This sort of behavior is typically related to the graphics card and its drivers and isn't a SketchUp bug. This is especially the case when the behavior changes after a period of use. SketchUp 2017 requires graphics cards that are up to handling OpenGL and handling it well. There's no offloading the graphics card's work to the CPU as in older versions. With Windows, the user can try to update the graphics drivers from the card's maker. With Mac it's not usually possible to do that. The graphics drivers are part of OS updates that Apple pushes with some frequency.
