    How to project Google Earth Snapshot to terrain
    3 Posts 2 Posters 711 Views 2 Watching
    • F
      filipebonito
      hello,
      i've made a terrain from a topography survey contour lines and i would like to have the Google Earth Snapshot texture projected to it.
      the problem is that it's a big area so the Google Earth Snapshot from geolocation is too small (big pixels when zoomed) so i added more zoomed imagery, it's about 35 faces now.
      the problem is that i want to project all of these faces to the terrain, and i don't have a clue how to do this...
      if i try to combine the textures to a single texture, i get errors on some of the snapshots, and the final result is also very pixelated...
      you can find an example file here:
      https://drive.google.com/file/d/0B7MYfNyO00_2VHRPN2xmc2xETUk/view?usp=drivesdk
      what can i do?
        Combining textures resamples the image to keep file size manageable.
        You could also composite the image in an image editor to get the result you want. Or source higher-res maps from another source
        • F
          filipebonito
          hello rich, thanks
          i ended up extracting a hi-res image from google earth and project it to the terrain, thanks
