Making Copies
Hi everybody :
Is it possible to make copies of an object....but copy it in a curved shape ? Instead of copying an object X number of times in a straight line ? garystan -
Your question is a bit vague...
Have you looked at 'Grow' ?
http://sketchucation.com/pluginstore?pln=GrowOr copy-along-plugins, like:
http://sketchucation.com/pluginstore?pln=CopyAlongCurve
https://extensions.sketchup.com/en/content/pathcopy
etc -
You can also use the rotation tool with Ctrl pressed to copy in a circle (or parts of).
You must always put an image: text is never sufficient!
Register LoginAdvertisement
