    Can't get into Sketchup Warehouse site normal way
    7 Posts 3 Posters 964 Views 3 Watching
    • L
      launok
      Hi there,
      Since today when opening the Sketchup Warehouse site a message comes up reading: Your connection is not private
      Attackers might be trying to steal your information from 3dwarehouse.sketchup.com (for example, passwords, messages, or credit cards). NET::ERR_CERT_COMMON_NAME_INVALID
      When I visited the warehouse 2 days back it was normal as always. Are anyone else experience the same?
      In the website link the https:// shows a red line drawn over that part of the url.
      Laura
        https://status.sketchup.com/?hl=en
        Maintenance I would imagine
        • jujuJ
          juju
          Isn't the access to pre SU2015 users being removed?
          • L
            launok
            Gosh, access too! ๐Ÿ˜ฎ I can remember a banner message which states that from 1 Jan 2017 downloads for models prior to SU 2015 will no longer be available but nothing regards access to the site. I hope this is not the case as I am a newbie who has uploaded 1 model so far to the warehouse and would like to share more in future.
              Sharing will always be possible. It's just that if you use older versions of SketchUp you won't get to import the models into SketchUp.
              Likely all models will only be opened by 2015 and above.
              • jujuJ
                juju
                Oops, my bad. That sounds more correct... Sorry to cause you worries...
                • L
                  launok
                  Quite fine! ๐Ÿ‘ Well it's the 1st of a new month, sounds like maintenance then.
                  EDIT: And whoopey, site is back up again!!! ๐Ÿ˜„
