    How to prevent texture from scaling
    7 Posts 5 Posters 9.3k Views 5 Watching
      Scamparelli
      Hi all,
      This is my first post on here, but may I say what I great forum - has been a massive help with my learning of SU Pro!
      I need some advice on a problem I have with creating Dynamic Components with regards to Textures:
      So I have created a simple component which resizes along X:
      Set at 1500mm:
      http://i807.photobucket.com/albums/yy360/Scamparelli/SketchUp Forum/1500.jpg
      http://i807.photobucket.com/albums/yy360/Scamparelli/SketchUp Forum/1500.Close.jpg
      Set at 200mm:
      http://i807.photobucket.com/albums/yy360/Scamparelli/SketchUp Forum/200.jpg
      http://i807.photobucket.com/albums/yy360/Scamparelli/SketchUp Forum/200.Close.jpg
      As you can hopefully see, the Texture is rescaling, but I can't find a way to prevent this from happening..
      Hopefully I am missing something quite obvious!!
        http://sketchucation.com/forums/viewtopic.php?p=524808#p524808
        much discussion about this over the years
        • P Offline
          pcmoor
          right click the component, then from the menu select make unique if there are other components at a different scale, and then select scale definition
            Scamparelli
            Thanks Rich,
            This video helped the most (even though it is in Russian!): https://www.youtube.com/watch?v=TWGGfoR5slI
            One thing to note, is that the texture must be applied AFTER you have followed this method. If you apply during creation of each element, it won't work..
              toddster
              I watched that russian video and I see that this work around works, i just cant figure out what he is doing exactly, can someone help explain it to me, i see him using a tool I dont have on my screen and then clicking over some of the faces of the cube but not all of them..sucks being a noob
                I thinks it's one of Jim's plugins. Not sure which though?
                • G Offline
                  goga63
                  This is my video (I used a method which is suggested Tig) . It's simple - inside the component, I put another component (scaler) and the prescribed attributes.
                  Scaler can be made invisible.
                  scaler.skp
